Author Topic: Sony PS-4300 record player motor not turning  (Read 2353 times)
Offline AndyMacSteveTopic starter
« on: January 24, 2018, 02:37:08 am »
My Sony PS-4300 record player has a problem that when I press play the turntable motor doesn't spin by itself when I press play
What is the problem?
Could it be the motor? A fuse? Connection problem, or a capacitor or circuit board problem?
Offline zvonex66x
  • Country: hr
Re: Sony PS-4300 record player motor not turning
« Reply #1 on: January 24, 2018, 06:25:59 pm »
You should take measurements.... It can be any problem...
Offline coromonadalix
« Reply #2 on: January 25, 2018, 02:37:49 am »
this is a direct drive motor, check the ac selector switch if there is one, powersupply capacitors    etc
service manual : https://elektrotanya.com/sony_ps-4300_turntable.pdf/download.html       whait  for the get manual
or this one :   https://www.vinylengine.com/library/sony/ps-4300.shtml
publicity  loll    : http://www.gammaelectronics.xyz/audio_03-1977_sony-ps-4300.html
