hi All!
I have a really nice vintage Sony PS-X65 turntable of the "PS-X" family. It's broken and I am trying to learn electronics as I repair it. It's not as bad as it sounds. I'd like to discuss the brushless slotless motor that is used in this family. It has never held speed properly (lots of wow and flutter) and only recently have I made some headway in figuring out why. I think it is the "hall element" sensors inside the motor which are supposed to do the commutation and which do not appear to work. I have obtained a parts donor and research table; a PS-X40 which does work.
My plan is to reverse engineer the specifications of the hall element in the motor and then replace the elements with a modern sensor such as an Allegro 1360 (Hall Effect Sensor IC). My problem will be that it is unlikely to be a drop-in replacement and that I do not have enough Electronics know-how to easily create a work-around. (I am a mechanical engineer and very new in the electrical hobby).
Here is what I assume about the original hall element: I assume it is a wheatstone bridge with one or more of the legs being magnetoresistive. I have been studying these sensors and they appear to be quite challenging to use due to temperature and strain sensitivity drift problems.
I furthermore assume that with the replacement IC the basic characteristics should be much more stable but I am not sure how to adjust my circuit for this amplified, ratiometric sensor.
I have one concrete question:
Is it reasonable to use the excitation voltage intended for the ?wheatstone bridge? hall element as the power supply for my ratiometric IC? Seems like a good idea to me...but then I am new at this.
I have some pictures from photobucket: the thumbnails are shown but you can click the image for full size
Here is a picture of the motor winding: Two phases driven by +30V/-30V
Here is a close-up of the hall elements. I think one was dead/flatline and during my troubleshooting I think I killed the second one (hence the PS-X40 donor machine)
Here is the circuit: Sorry for the poor quality. I'm not concerned about the left-hand side.. probably works. The RH side starts with what I think is inside the hall elements indicated in the blue rectangles... then op-amp to drive the PNP/NPN. There is feedback to the opamp
the circuit is laid out in US Patent 4135120 and there is an ok explanation in that document.
I think it is simple as this:
Hall Elements provide sine-wave for commutation
feedback on motor winding to opamp compensates for the zero crossing of the NPN and PNP that would otherwise create notchiness
PLL Circuit obtains speed feedback from the rim of the turntable platter and adjusts the gain which is the excitation voltage of the hall element sensors
My first post!
Mark
