I am trying to repair a Sony PVM-2044QM. The full service manual is here:
https://archive.org/details/sony_PVM-2042QM_2044QM_Service_ManualWhen the monitor is turned on, the top part is a little bit distorted and white lines are displayed. See picture below.
After a few minutes the lines slowly goes up and disappear completely.
I think the issue is called vertical foldover from what I read
https://www.repairfaq.org/samnew/tvfaq/tvvfold.htmFrom the website it says "Probable issue is a charge pump that generates a high voltage spike to return the beam to the top of the screen".
So far I have checked/done the following:
- Checked for cold solder joints
- Replaced the following capacitors: C651, C501, C559. C502. C535. C519. C520. C535, C520. C547. They either had high ESR value or obvious sign of leakage.
- Reflowed solder joint of IC501 (UPC1377C) which is managing horizontal and vertical deflection.
What should I check next ? What kind of failure would solve itself with the monitor heating up ?
Any advice would be appreciated.
Thanks
