Author Topic: sony str-av900  (Read 3566 times)
Offline daine22Topic starter
sony str-av900
« on: December 20, 2014, 09:58:17 am »
hello guys,
what diode can i use to replace US1060M on my Sony STR-AV900 FM/AM Stereo Reciever
http://www.datasheetarchive.com/dlmain/Databooks-5/Document290-10324.pdf
TYIA
Offline tautech
Re: sony str-av900
« Reply #1 on: December 20, 2014, 09:52:43 pm »
Welcome to the forum.
By your posted link, one would assume it is in a power path not a signal path.
If this is the case, it is likely it's spec's are not critical unless in a SMPS.
Go to one of the big component suppliers websites and apply the filters for selection to match your requirements.
http://nz.rs-online.com/web/c/semiconductors/discrete-semiconductors/rectifier-schottky-diodes/
Offline Richard Crowley
  • KJ7YLK
Re: sony str-av900
« Reply #2 on: December 20, 2014, 10:02:48 pm »
We can guess from that Japanese spec page, but it would be extraordinarily helpful to see the schematic diagram of where the diode is being used in the circuit.
Re: sony str-av900
« Reply #3 on: December 21, 2014, 08:26:30 am »
thanks guys for the reply! the diode is on control computer IC, can i replace it with 1N4148 diode????
TYIA
  • KJ7YLK
Re: sony str-av900
« Reply #4 on: December 21, 2014, 01:40:14 pm »
It makes one wonder how it failed open?
And how you discovered the problem?
And whether the battery needs replacing also.
