Author Topic: Sony STR-DB870QS standby transformer  (Read 700 times)
Offline denistenTopic starter
  • Country: bg
« on: April 16, 2023, 07:28:55 am »
Hi everyone, i am a newbie here and i hope i will find the help i need. I have the above mentioned receiver with standby transformer's primary coil damaged. I have searched the net without success to find any tech data about this transformer. I have only the Sony part number1-437-313-11 and TAM Malaysia M0126. I guess i could find replacement for it, but i need to know the secondary coil voltages and VA. It is 220v on the primary. It has 5 pins on the secondary, the outer two are not used and i have 6.5 ohms between pins 2and 4, 3,9 ohms between 2 and 3, and 3,6 ohms between 3 and 4. Can someone determine looking the schematics what voltage i need on the secondary? This transformer is mounted on a small board called AC board and the only voltage going out of it is 8v to the main cpu. Other 4 pins on the connector CN51 are ground and 3 incoming voltages, i think. There are two transistors right after the transformer and i am wondering if it is 15-0-15 or maybe something else. Any thoughts about it will be highly appreciated.
Offline Chris56000
Re: Sony STR-DB870QS standby transformer
« Reply #1 on: May 02, 2023, 09:04:32 pm »
Hi!
There is a supplier that list your transformer as an orderable spare part here:–
https://www.google.com/url?sa=t&source=web&rct=j&url=https://www.searspartsdirect.com/product/64koykq1kb-0003-474/id-1-437-313-11&ved=2ahUKEwjln5uJxdf-AhVKZMAKHb7cCuEQFnoECBUQAQ&usg=AOvVaw2W06ajnvAo4Rpxg59Foeun
Alternatively, if that's too expensive and you want to try replacing it yourself, it's 6–0–6 V at about 500 mA!
You should be able to find something in the encapsulated "block" type of transformer about 4 to 6VA rating that should fit the PCB, altho' you might have to drill additional holes in suitable places in the PCB to fit a new one!
Chris Williams
« Last Edit: May 02, 2023, 09:11:37 pm by Chris56000 »
It's an enigma that's what it is!! This thing's not fixed because it doesn't want to be fixed!!
