I have a TCM-848, purchased ~1990 or so. It is like new, except it doesn't work. As far as I can remember, it never worked. I have a faint recollection that it did not work when I brought it home but I never returned it - probably because I lost the receipt or something like that.
I have minimal repair skills, especially mechanical repair skills. The unit, while retro (came out in 1987 I believe), is not particularly valuable. Even for parts only would likely $bay for US$10-20 I would think. I have done some due-diligence and can't locate a service manual other than at a price near what the unit is worth.
My hope is that I can get some help with a repair or some advice in that regard.
Here are the symptoms...
When you insert a known working cassette, it will not play. You can hear a brief and appropriate (e.g., music or data) sound from the speaker and it will 'lurch' but not play and it is not moving the tape. This is exactly what I remember it doing and is what it does now.
REW and FF do not move the tape (although you can hear it trying.
Cover off with no cassette inserted, the two belts (see below) move freely when PLAY is pressed.
I can't say whether they are loose or tight because I have no reference. But, the belts move and do not look like they are slipping at all. From reading, I know that these belts degrade, but, again, the unit did not work when new and with that same symptom, based on memory.
The spindles/hubs, not sure of the right nomenclature (see below) move (with no cassette installed) as they 'should' when PLAY, REW or FF is pressed.
If a cassette is inserted, those spindles do
not move and, with PLAY, I can sometimes hear some loud squeaking, but not from the speaker. I have not kept it that way for long as I don't want to damage it further.
So, what do you think? Can this be fixed easily and by a low-skilled person? What is my next move?
