Hi all,
I've got a Sony KV-14LM1E without remote control which shows blue flashes while also displaying the signal applied.
It's like part of the blue color comes and goes rapidly but the actual flashes are "bluer" than what they would normally be if the blue color would be missing and coming back.
I hope this makes sense!
I tried touching the joints on the heavier parts and replaced the color amplifier on the neck board just in case it was faulty but the problem persists.
Hitting with a stick does not alter the problem but the flashing is quite rapid and eye catching so it's not easy to see if I can actually affect it by the hit test.I also tried flexing the board in various place but I didn't see any change; again the flashing is obscuring things a bit but I would probably know if it changes frequency; fixes itself etc.
I would say it's consistent so I guess that this behavior rules out any connection problems.
I don't yet have a sony remote control (plan to get one from a friend) so I can't access the diagnostic menu..
Any ideas on what I could check next?
ps: There's full schematics on the service manual
https://elektrotanya.com/sony_kv-14lm1e_fe-2.pdf/download.html#dledit: I got the remote and the errors are as follows:
OCP > 124
IKR > 11
8V > 2
Ι cleared those because I'm not sure if anyone else might had a go to repair it and maybe forgot a connector or so throwing an error.
The one that went +1 again is the IKR (points to horizontal output circuit
which seems fine since I do have horizontal deflection)
