Author Topic: Sony TV KD55X8500G power on issue - schematics? ideas?  (Read 1197 times)
Offline DTJTopic starter
« on: January 07, 2023, 06:04:01 am »
My 3 year old Sony TV shutdown unexpectedly the other night and now will not power on. The factory reset doesn't work either. It appears completely dead.
I found a service manual for an earlier variant online at https://servlib.com/sony/tv/kd-55x8500a.html?start=0
Being completely dead had me hoping it was just a fuse or similar but I cannot see anything obvious.   :--
Before I started poking around further I wondered is there such thing as schematics available for these things?
If so where will I find them?
Thanks
Offline fzabkar
The following users thanked this post: DTJ
Re: Sony TV KD55X8500G power on issue - schematics? ideas?
« Reply #2 on: January 07, 2023, 06:40:28 am »
Excellent. Thanks Frank. No detail schematics but much more information than I had.
Cheers.
« Reply #3 on: January 08, 2023, 11:11:11 am »
Follow up for posterity.
The 3V3 stay alive rail was not present.
It had a DDA010 switching supply chip driving a transformer followed by a schottky rectifier.
The SB260 schotty had failed S/C. I replaced it and it now works ok.
The following users thanked this post: bow
Offline bow
« Reply #4 on: November 14, 2024, 08:48:41 am »
Thanks! I found the same issue with my Sony XBR-75X900F. The TV suddenly wouldn’t power up. After replacing the Schottky diode SB260, it’s now working again. I was worried the eMMC might have been damaged from wear after 6ish years.
I also have an SB560 on hand, so if the issue happens again, I’ll try replacing it with that.
