Author Topic: Sony tv power board  (Read 3055 times)
Offline onis_ukTopic starter
Sony tv power board
« on: March 20, 2022, 06:36:52 pm »
A friend of mine said his Tv just went off and won't come back on and asked me to have a look as I have some small modicum of electronics experience.
The main power board has 2 failed diodes in the bridge rectifier, just wondering what could cause this kind of damage? Would just swapping them out be likely to fix it?!
I was drawn to the top left diode as there is clear heat damage on the legs but the lower left is also open circuit.
Offline Jeff eelcr
Re: Sony tv power board
« Reply #1 on: March 20, 2022, 08:06:57 pm »
I would replace all 4 and check electrolytics after them.  it is a good idea to post model number, chassis and board numbers on some types of equipment if not schematics to make it easier to tell whats going on.
Jeff
Online inse
« Reply #2 on: March 20, 2022, 09:21:20 pm »
Once again I am puzzeled by Sony engineering.
The diodes are in an area marked as "secondary", why would you have a bridge rectifier here?
The mains input is clearly on the left lower corner, but I can't see the bridge rectifier there (is it hidden under a heat sink?)
It is difficult to apply additional heat sinking to this diode package, I would replace them and hope for the best.
I would replace the electrolytics only if bulged, leaky or otherwise suspicious.
They apparently are quality parts, if you decide to replace them, select proper parts, not random stuff.
« Last Edit: March 20, 2022, 09:29:44 pm by inse »
« Reply #3 on: March 20, 2022, 09:35:13 pm »
Jeff
Ah yeah sorry Jeff, its a GL72 variant board APDP-225A1 I believe to be the PN.
« Reply #4 on: March 20, 2022, 09:38:49 pm »
I must admit this confused me too, there is rectification in DC side post transformer?!
All the caps on the board look ok, maybe the 2 brown 68μf caps look a little puffed up so might as well swap them out too!
Online inse
« Reply #5 on: March 21, 2022, 05:28:20 am »
The 68uF look normal to me, do the PCB traces confirm the diodes are arranged as bridge?
« Reply #6 on: March 21, 2022, 08:50:03 am »
not 100% sure to be honest, best I can do it hold it up to the light, but I think so yes.
« Last Edit: March 21, 2022, 08:51:45 am by onis_uk »
Offline xavier60
« Reply #7 on: March 21, 2022, 11:21:59 am »
It's normal for the secondary of a resonant converter transformer to be full wave rectified.
HP 54645A dso, Fluke 87V dmm,  Agilent U8002A psu,  FY6600 function gen,  Brymen BM857S, HAKKO FM-204, New! HAKKO FX-971.
The following users thanked this post: onis_uk
« Reply #8 on: March 21, 2022, 11:38:33 am »
The diodes have LT7114 SB5150 on them, possibly this datasheet.
https://www.wontop.com/uploadfiles/56/sort_excel/pdf/sb5150.pdf
Could someone assist me in picking an equivalent on RS as I can't find the exact same part!
« Reply #9 on: March 21, 2022, 11:44:05 am »
« Reply #10 on: March 21, 2022, 11:50:58 am »
Offline Mike_NZ
« Reply #11 on: July 09, 2022, 04:39:10 am »
I wonder if the power board has been fixed?  My TV has exactly the same problem  :palm:
