Author Topic: [Solved] Sony XBR IC ID  (Read 580 times)
Offline jeffjmrTopic starter
« on: May 02, 2022, 03:19:02 pm »
Trying to repair a common problem; Sony XBR XXX930D no power.
Sony replaced the power board once. Problem reappeared a few months later. All indications are this IC is the culprit, and this replacement board shows signs of this IC having been replaced along with the installation of a 72K resistor between pin 8 and the cap to the right. I have removed the resistor to ID the chip.
But no combination of the codes on the chip are returning a hit. Pretty sure it is a LDO DC buck converter but no schematic or parts list in the service manual. Troubleshooting just says replace the board.
Any ideas?
Thanks,
Jeff
1476694-0
« Last Edit: May 02, 2022, 05:58:16 pm by jeffjmr »
Offline fzabkar
Re: Sony XBR IC ID
« Reply #1 on: May 02, 2022, 05:27:41 pm »
I couldn't find anything in TI's part marking database:
https://www.ti.com/packaging/docs/partlookup.tsp
Re: Sony XBR IC ID
« Reply #2 on: May 02, 2022, 05:56:50 pm »
Yeah, neither could I, but several other units have a TI TPS54334, which I now believe is the same or equivalent part. Have one on order.
Thanks.
Jeff
The following users thanked this post: fzabkar
