Author Topic: sop8 unknow  (Read 1538 times)
Offline gbr600Topic starter
sop8 unknow
« on: September 12, 2020, 02:32:30 pm »
Goodmorning everyone i came across the repair of an elevator inverter but i can't find the technical data sheet of this smd sop8 component marked sgc does anyone kindly know it?
Offline TheMG
Re: sop8 unknow
« Reply #1 on: September 12, 2020, 03:25:41 pm »
Some context would definitely help. What is the manufacturer of the inverter? What part of the circuit is this IC from? Any idea as to its function?
I don't even recognize the logo on that IC. Without more information it will be pretty hard to find anything.
Re: sop8 unknow
« Reply #2 on: September 12, 2020, 05:49:08 pm »
the inverter is otis ovfr3
is the integrated is placed at the serial input that goes to the panel board
Offline gamalot
  • Correct my English
    • Youtube
Re: sop8 unknow
« Reply #3 on: September 12, 2020, 07:06:27 pm »
Its a PLCDA12 TVS array from Protek Devices
http://www.protekdevices.com/xyz/documents/datasheets/plcda.pdf
I'm a poet, I didn't even know it. |  https://youtube.com/@gamalot | https://github.com/gamalot
Re: sop8 unknow
« Reply #4 on: September 12, 2020, 08:30:11 pm »
Great!!Thanks you so much for the help!!!!
