So this is one of my last old 'gambling debts' that I want to try to fix, its getting a little old to only have one of these functioning.
So the problem is the device is 33V, and it was getting stuck at 16.5V. However during probing I managed to short the LDO out some how (5V behind the heat sink), I think one of the channels to ground, not input to output, given how the chip pinout is..I am not sure why it went bananas after shorting a LDO to ground, it is possible I some how shorted input to output (3 to 1) but I don't think so, maybe a control loop went bananas.
But this caused it to make a horrible squealing noise while it was on and then to blow a fuse. I have left it alone for the longest time.
I have a sorensen XKW schematic, but I am not sure how its different from DCS.
I took the PCB out and I have no idea how to approach it. I was first going to replace the 3 LDO's, since I have them (lm337 and 2x ti 5V reg), and I know something bad happened to the rail with my multimeter probe, then see if it at least works without triggering a fuse.
Why a 5V LDO caused squeeling/whine from what I guess is magnetics i don't know, cascade failure comes to mind because it is only a 1 amp reg, I measured it in circuit and I don't see evidence of a power down low impedance condition,
Is it possible there was some kind of 'hiccup' caused by the interruption of the power rails when I abruptly changed voltages on one of the regulators?, and that it was some kind of soft fault? I thought to replace the fuse and try it again.
