Ok, now I have tested while circurit is mounted and there is power to the soundbar.
I have found that the motherbord powerspuply inside the soundbar is 3.3 volt.
I have also found that if i `manually` supply 5v to the wifi module the wireless speakers starts to work
- that god news. This is tested with an external powersupply connected to the wifi module Vcc (3.3v is not working)
I have messure a usage of aprox 850 mA to the wifi module while 5 v is Applyed and speakers is playing Music - anyone know if this is this an expected consumption for a wifi / radio module ? (I was expecting something like 2-300 mA based on a guess)
This leads me to conclude that the ic that is deffective is a `step up` From 3.3 v to 5 volt.
Given the fact that this is a SOT 6 pin, have You any clue about what substitut ic I May use ?
Or should I simply make a sepperate 5v supply and use that for the wifi module - it would work
I do have 19 volt availbe also on the buildin power supply so maybe I should simply add a 7805 with a small capacitor
Inside the soundbar - og do you have any other suggestions how to fix easyly
