Fuse is ok, continuity checked. Which component is the voltage regulator and what would the expected value be?
I'm not sure if the LCD screen itself is working, it is not recognized connected to a laptop and there is a LED on the board (listed as LED3 on upper right side of image), this is not lighting when 12v PSU is connected to board.
