idk slide switches and crimp/connectors work better with grease you got a metal on metal contact.
there is alot to read about this, but typically people will at least put a smear of vasoline or something on a multimeter contact. its not a watch, your not gonna bog down a mechanism, it reduces fretting/friction and typically improves the contact since the grease is thermally conductive
the only time I get paranoid about grease and electronics is on non solid coaxial cables since they might wick, especially the tape wound microwave type.
Different story for switches, that is up for debate.. (I won't do more then oil)
my welder IGBT goes as far as having like a jelly on top of the dies, then there is a buncha contacts that push through the jelly into the contact pads (miller welding machine). I bet it would do pretty poorly without it.
in all likelyhood the telephone system would be total shit without silicone grease filled IDC's
ideally the contacts would be submerged in something, air does nothing good for them, unless they need to haul ass... this is what the telephone company does with silicone grease, and IGBT get like a jello on top (thicker then grease).
you only have problems when things are either mega low force contact or get slowed down too much. a reed relay is something that probobly should be totally clean. A regular relay... not sure. might need redesign of the armature for lower fluid friction ... but they have special oil filled relays and switches that can take much more power.
but your problem is friction and metal on metal side wear
people freak out when you put grease on gold btw, but its still a metal
