Author Topic: Sourcing replacement USB3 connector  (Read 1495 times)
Offline james_sTopic starter
« on: January 10, 2021, 09:05:48 pm »
I've got another project here that has been deceptively difficult. This is a HP small form factor PC, not sure of the exact model because there's an asset tag over the label which I don't want to remove but it's a relatively new i7. One of the front panel USB connectors has been broken by some monkey (doctor) impatiently jamming a plug in there the wrong way around and now the contacts are all mangled and it will need to be replaced. This connector is soldered directly to the motherboard and to complicate matters it is designed so that the front 2/3 of the connector sits into a cutout in the PCB to reduce the height. The only marking I can see on these is "tconn 170213" which has come up dry but perhaps my google-fu is failing me. I did find what I believe is the company that made these but I don't see anything quite like it in their offerings. Anyone got any leads? Otherwise I guess my only real option is trying to source a defective motherboard to cannibalize, perhaps some HP laptops of a similar era used the same connectors.
Pictures are of an identical intact connector because it's more readily visible than the broken one.
Online wraper
  • Country: lv
Re: Sourcing replacement USB3 connector
« Reply #1 on: January 10, 2021, 09:15:49 pm »
Your pictures have no details whatsoever. Is it TH or has SMT pins? How pins are arranged, etc? What is laptop/motherboard model?
« Last Edit: January 10, 2021, 09:21:36 pm by wraper »
Online wraper
  • Country: lv
« Reply #2 on: January 10, 2021, 09:23:17 pm »
« Reply #3 on: January 10, 2021, 11:17:47 pm »
Sorry, the pictures provide as much detail as I can get without completely disassembling the machine which is next on my list of stuff to do with it. I was hoping the number printed on it might help, or that somebody who has been through this before will have found something that fits.
That connector you linked is closer than anything else I've found, I will investigate it further, thanks.
Online wraper
  • Country: lv
« Reply #4 on: January 10, 2021, 11:19:34 pm »
Number printed on connector is most likely is a lot code or something like that.
Online wraper
  • Country: lv
« Reply #5 on: January 10, 2021, 11:27:24 pm »
The same thing with cheaper price and with drawing https://www.aliexpress.com/item/1005001456713135.html
BTW you should strongly avoid operating it with shorted USB pins. Even when off but with battery attached. There is a quite high chance of destroying CPU or chipset if there is a separate one.
« Last Edit: January 10, 2021, 11:30:53 pm by wraper »
The following users thanked this post: james_s
« Reply #6 on: January 11, 2021, 01:18:28 am »
Well I'm not operating it like that but the machine was powered up and operating when it broke, I have no idea how long it spent in that state before it was brought to me. There is no battery, this is a SFF desktop machine.
Online tooki
« Reply #7 on: January 11, 2021, 06:30:36 pm »
Check digi-key, they carry a ton of USB connectors, including the shorty ones like you need.
« Reply #8 on: January 11, 2021, 06:32:37 pm »
I did check, but I wasn't getting anywhere with the parametric search. I was hoping somebody might be familiar with the specific connector and could point me to a part number but it's looking like I'm going to have to remove it from the board and take some measurements.
Online wraper
  • Country: lv
« Reply #9 on: January 11, 2021, 06:36:59 pm »
And there is like 95% chance you won't find it at usual distros.
Online nali
« Reply #10 on: January 11, 2021, 06:41:23 pm »
Well it'll probably be one of these https://www.t-conn.com/en/product/series/USB/USB-3x possibly 18-30330-1A03-0
Note that from looking at some of the drawings the "170213" looks to be a date code which explains why it's not coming up in a search.
The following users thanked this post: wraper
Online tooki
« Reply #11 on: January 11, 2021, 08:07:28 pm »
But if you don't check, the 5% chance gets reduced to 0%.
« Reply #12 on: January 12, 2021, 05:14:42 am »
Well I'll take the PC apart this weekend if I have a chance and desolder the connector so I can get a better look.
