Unless it is under pressure, liquid water does not exceed 100C. Obviously, it would turn into a gas if it did.
The whole idea behind sous vide cookers is that you use a lower cooking temps (50-70C). If you wanted to boil the water you would use an ordinary pot.
With those two things in mind, I would choose a thermostat that was very close to 100C.
