OK, I've been reading about this transformer issue and noticed a few things. One, transformer posts asking questions are almost always everybody guessing. Two, a lot of people give up. Three, the people who get it solved always have a transformer not like mine.
So, I read that a three wire transformer like this is probably a center tap and would have two powers out (like +12v/-12v ---- Va and Vb) and a ground I think. In other situations, people would use one of the power wires and the ground and tape the other wire. In my case, all three wires connect to the main board. Next to the transformer is a bridge rectifier. I want to think the transformer is +12v/-12v but that cannot be right. It would have to be +12v, or +6v/-6v. That is because the capacitors on the board are rated 16v. I mean it could be a 16v transformer maybe, but is there such a thing. Anyway, that doesn't matter.
I have a "standard", 12vdc, power supply that I bought online. It only has positive out and negative out. How would I go about figuring out which of the main board wires to connect to? I hope I showed enough effort that someone sees I really am trying and will help me. Thanks.
