Hi All,
I am trying to repair an SSI PFQ355 power supply. Its not going well...does it ever?
It has 5 output voltages, +5v, +24v, +15, +15, +12. The +5 I think is 7-10 Amps. The others are probably closer to 1-2 amps.
Ive done the usual check, the caps all check out within spec and ESR.
Checked for any shorted or exploded components, none that I could find on a first pass.
The power supply just blows the input fuse, a 7 amp AGC type. Its spectacular and instant.
So I think something is definitely shorted but where?
I did pull the full bridge rectifier and up to that point, it wont blow the fuse. The bridge does seem to check out as well.
I did try to just power the board with my Rigol DP832 30v 3a (max one channel) and I didn’t get anywhere, no current draw at all.
I placed the DC + on the DC output of the bridge and - on the -. I could parallel up the channels?
My thought was I could at least see if something like a diode or transistor was getting hot.
2 things in the pictures, That resistor must have gotten really hot, I peg it as a 470 ohm (Yellow, Purple, Brown, Gold).
Does check out surprisingly at 460 ohm. But I can see the resistance wire burned in the outer casing.
That resistor was across the +5V output (between + and -). That gave the 5v output about a 24 ohm between +5v and Negative.
With it removed, its open i.e. no resistance between the + and - but it will still blow the fuse.
I don't think that has anything to do with it, it should at max draw about 208 mA (24 ohms 5v). I think its just a minimum load resistor.
Also the NTC has a chunk missing and yet also measures good. Resistance at room temp about 14 ohms, data sheet said 10 ohms.
I replaced it with an NTC I had that was close to the same size. Though it made no difference.
Im kinda at a loss as to where I should go from here. Should I just pull all the transistors, dual diodes and regulators?
Any thoughts would be great!
Thanks!!
