Author Topic: Unknown pink-ish component  (Read 872 times)
Offline morfi717Topic starter
« on: June 19, 2023, 10:37:03 am »
anyone has ideas on what the "bloated" pink-ish diode-looking element in the middle of the photo could be?
Offline BrokenYugo
Re: Unknown pink-ish component
« Reply #1 on: June 19, 2023, 02:12:58 pm »
Glass body makes me think diode of some sort. EDIT: Lack of polarity stripe makes that unlikely. Knowing what we're looking at would be helpful, what is the board from? What is it supposed to do?
« Last Edit: June 20, 2023, 04:31:52 pm by BrokenYugo »
Offline mikeselectricstuff
    • Mike's Electric Stuff
« Reply #2 on: June 19, 2023, 02:19:20 pm »
thermisor maybe?
Day Job: Mostly LEDs
Offline coromonadalix
« Reply #3 on: June 19, 2023, 04:07:23 pm »
i would say a diode like 1n914   1n4148 ???
take a meter and check in diode ...
Offline metertech58761
« Reply #4 on: June 20, 2023, 12:22:58 pm »
Thermistor would be my guess as well.
Offline xrunner
  • hp>Agilent>Keysight>???
« Reply #5 on: June 20, 2023, 12:37:16 pm »
Agree with the thermistor crowd. Most diodes have the cathode marked with a line (as in the picture you show).
Although I could be wrong about this and many other things.
« Reply #6 on: June 20, 2023, 03:52:30 pm »
gas tube discharge ???   that smal ????
Offline floobydust
« Reply #7 on: June 20, 2023, 04:49:26 pm »
What does the part measure for (in circuit) resistance, and while your finger heats it up. That will show if it's a thermistor.
But all those all use MELF diode packaging - red glass, not this strange beige.
As a GDT it doesn't have special PCB trace spacings or a path to ground.
« Reply #8 on: June 21, 2023, 09:34:53 am »
It was indeed a thermistor:) thanks!
