hi,
My Stanford Research SR-620 Display LED's do not turn On when mains power switch is turned On.
The Fuse has not blown, The Fan will not turn On, yet one-small audible "click" from one of the relays can be heard after the power SW is turned On. No audible sounds from any keypad button-presses.
Voltages across the PS Caps read 10V, 10V, 12V, 12V, & 22V, 22V.
Two of the three LM317 PS regulators provide valid regulated voltage at their outputs. The third LM317 gives a -1.2V output, so something is shorted out.
- I will be looking for heat & current surge on the PCB components.
Does Anyone have detailed schematics or detailed repair knowledge of this unit ?
thank you,
