I would guess that the horizontal transistor has died, probably from either dry joints on the LOPT, flyback tuning capacitor or the power supply. Replace with only the exact device, and resolder all the joints in the LOPT area, and check the capacitors and the resistors there, along with the joints on the drive transformer. Power supply voltages should be marked on the PCB from the power supply. Check them all, there is a similar SMPS there with the same issues.
As well clean the EHT cables and the splitter, so that there is no dust to cause a flashover which will kill the new transistor.
