I used both a Weller temperature controlled iron and Hakko FR-301 for the large tabs, the Hakko for the small tabs and + terminal. Caps were removed with relative ease. A Chemtronics 1/4" wide braid was used to clean up any residual that kept the tabs from loosening.
Caps are Nichicon, PET, similar C-V, radials except for the 1200uF/100VDC which is a snap-in United Chemi-con.
