Author Topic: Step down power converter repair help for a beginner  (Read 4466 times)
Offline SteveRosenlundTopic starter
« on: March 27, 2016, 01:27:43 am »
Hello
This is probably a simple repair but I'm new and not sure where to begin. I purchased two of these step down power converters from eBay for a couple bucks just to have something to play with. One works and one doesn't. The seller is sending me a new one to replace the defective one but I want to fix it as practice. I've drawn out a board layout as best as I can figure but there are some components under the display I can't see.
Any advice?
Re: Step down power converter repair help for a beginner
« Reply #1 on: March 27, 2016, 01:43:36 am »
This is what I have so far.
Offline mariush
« Reply #2 on: March 27, 2016, 02:47:26 am »
That LM317 is an adjustable linear regulator that takes whatever input voltage you have and outputs a particular output voltage, probably something around 2.5v - 5v . That voltage probably goes to the numeric led display which probably has a tiny board under it with a microcontroller that reads the set output voltage (and maybe current) from the switching regulator and displays it on the numeric display.
If the linear regulator isn't working, then that 3 digit numeric display won't turn on, and quite possibly the input led also won't work, but the switching regulator is independent and may still work.
My suggestion would be to look at the pinout of that LM317 ( it should be input voltage , ground/adjust , output voltage, not necessarily in this order, find a datasheet or just use your multimeter's continuity mode to see which pin goes directly to Input +v  and which one goes to ground / Input - on that two wire header..
With power going in through those two wires, then measure the output voltage of that linear regulator .. if you don't see anything there's your problem - the regulator's dead. You can also figure out what output voltage the regulator is supposed to do by the two resistors connected to the gnd/adjust pin (see datasheet) .. if you measure something other than what's supposed to be set by resistors, again the regulator's probably dead.
Next point of failure would be the diodes. I think the D1 diode is used as some cheap basic reverse voltage protection - if you wired the board with the input wires the wrong way around and left it there for a bit of time, you may have popped that diode, which means the switching regulator won't see any input voltage.
Check the other diodes as well... use the diode measurement function on your meter.
Next, look at the LM2596 switching regulator ic ... look at the datasheet and look at the pinout. Figure out the input voltage + and gnd pins and put the multimeter on those  and if you don't measure anything, there's something faulty (open) between this input pin or gnd pin and the input voltage header.
Offline Hobby73
« Reply #3 on: March 27, 2016, 03:42:15 am »
It might just be the lighting on your photo, but the surface of the LDO on the bad module looks much lighter in color that the one on the good module.  It's common for LDO's to run warm/hot, but they can overheat to failure if you exceed their rating.  I wonder if this lighter color is a symptom of overheating?  I know you never got it working, but who knows what (destructive) testing was done before it got to you?
« Reply #4 on: March 27, 2016, 06:06:59 am »
Wow thanks for the replies. I will definitely follow all your advice. I'm going to check the pins on the lm317 and put my scope on the output side looking for stuttering.
Before posting I did check voltages comparing good with bad and the first think I noticed was the first diode voltage drop was different from one to the other. I don't remember the values off the top of my head but they were different by enough for me to notice.
I believe they're Schottky diodes.
« Reply #5 on: March 27, 2016, 10:16:36 pm »
The D1 diode is shorted. I've ordered a replacement. Any reason I can't use a regular silicone diode in its place to see if any other components are bad?
Edit:
I also noticed there's no output on the Lm317 center output pin. I'm getting voltage in but nothing out.
« Last Edit: March 28, 2016, 02:42:46 am by SteveRosenlund »
