Author Topic: [SOLVED] Stereo amp cracking and popping one channel only  (Read 9283 times)
Offline negativ3Topic starter
  • Country: th
« on: August 06, 2016, 04:43:17 am »
Hi all,
I have a Creative Inspire T3130 2.1 channel amp connected to my Raspberry Pi running Openelec.
The audio right channel audibly cracks and pops intermittently regardless of the volume setting (turned all the way down it still presents the problem).
Left and sub channels work just fine.
What in your opinion could be the cause? A lot of hot snot on the board is brittle and has just falls off at the slightest touch.
Thanks all.
« Last Edit: August 07, 2016, 09:04:58 am by negativ3 »
Offline cncjerry
Re: Stereo amp cracking and popping one channel only
« Reply #1 on: August 06, 2016, 04:59:55 am »
Inter-stage coupling cap if it uses them.  Could be a poor/cold solder joint on the input side.  Try moving the cables around and flexing the board a little.  A little work with a scope should find it quickly.
The following users thanked this post: negativ3
Offline jh15
« Reply #2 on: August 06, 2016, 05:10:51 am »
noisy transistor too. Try some cooling spray. I think of 2sc 1458 memory maybe wrong of this, but was common.
Tek 575 curve trcr top shape, Tek 535, Tek 465. Tek 545 Hickok clone, Tesla Model S,  Ohio Scientific c24P SBC, c-64's from club days, Giant electric bicycle, Rigol stuff, Heathkit AR-15's. Heathkit ET- 3400a trainer&interface. Starlink pizza.
Offline cvanc
« Reply #3 on: August 06, 2016, 01:21:42 pm »
Several questionable solder joints on the board...
Offline voltz
« Reply #4 on: August 06, 2016, 09:27:39 pm »
+1 (and well spotted)
And that is the Audio IC. Possibly explains the fault even with volume down. Re-solder all audio IC pins.
If that still does not work, try tapping the PCB with insulated handle of a screwdriver and see if you can locate the area of the PCB that has biggest effect on the noise.
If no effect, then could be an unstable component, try 'freeze it' spray and locate the component that way.
  • Country: th
« Reply #5 on: August 07, 2016, 03:10:13 am »
VERY well spotted cvanc. I will go over the whole board for good measure.
Thanks all for the tips. Will determine the audio IC and get the datasheet as well in case the dry joints do not fix.
  • Country: th
« Reply #6 on: August 07, 2016, 04:54:14 am »
Re soldering those dry joints did the trick. Thanks all for your excellent contributions.
