Author Topic: STM8 blue pill programming not working, GND pin no continuity repair  (Read 595 times)
Offline dusanTopic starter
  • Country: sk
I just bought another two STM8 blue pill boards from aliexpress from this seller: https://www.aliexpress.com/item/4000044680163.html, both could not be programmed. I found out that the GND pin on the programming header was not connected to ground, probably internal ground did not connect to via or something. Anyway I added small bodge to ground plane and programming now works.
The following users thanked this post: elecdonia
Online radiolistener
Re: STM8 blue pill programming not working, GND pin no continuity repair
« Reply #1 on: December 05, 2022, 01:01:19 pm »
STM32F103C8T6 blue pill has much more resources...
Offline ledtester
« Reply #2 on: December 05, 2022, 01:42:35 pm »
You should ask for a refund and write a review detailing your experience.
« Last Edit: December 05, 2022, 01:44:15 pm by ledtester »
  • Country: sk
« Reply #3 on: December 05, 2022, 03:27:14 pm »
Yes but consumes 30mA and STM8 only consumes 7mA
