Author Topic: Strange flex cable traces material?  (Read 2299 times)
Offline frenkyTopic starter
  • Country: si
    • Frenki.net
« on: August 01, 2016, 05:35:33 pm »
I'm trying to fix a pump controller for a friends friend.   ;)
There was a shorted voltage regulator that I have already fixed and the only thing left to repair is teared flex cable.
Traces are sandwiched between two layers of plastic foil. So I peeled top layer off.
Traces are made from some kind of silver sparkly stuff...
I tried soldering it but the traces just turned grey and solder did not stick to it.
Anybody has an idea how to solder to it or fix it in some other way?
Tnx.
« Last Edit: August 01, 2016, 05:40:03 pm by frenky »
Offline Twoflower
Re: Strange flex cable traces material?
« Reply #1 on: August 01, 2016, 05:52:07 pm »
You might try some electrical conductive glue/colour (something like LOCTITE® 3863) to repair the flexcable. Probably even teh manufacturer used such material to print the wires on the foil.
  • Country: si
    • Frenki.net
« Reply #2 on: August 01, 2016, 07:01:55 pm »
Thank you for a good advice. :-+
Offline Kilrah
« Reply #3 on: August 01, 2016, 07:12:01 pm »
Ugh, these things are awful. Super fragile and a PITA to repair.
Online mikeselectricstuff
    • Mike's Electric Stuff
« Reply #4 on: August 01, 2016, 07:28:08 pm »
It's printed silver ink. May be fixable using silver paint or epoxy. You won't solder to it.
Day Job: Mostly LEDs
Offline Twoflower
« Reply #5 on: August 01, 2016, 07:31:11 pm »
Actually the more time I'm thinking of it, the more sceptical I get with my own suggestion. :-//
As the tape moves the connection will break immediately. At least you need to do something in addition to either prevent movement in the defective area. Or adding some thin copper wires bridging the crack and glue them with the stuff and probably stiffen the area as well.
Offline RobK_NL
« Reply #6 on: August 01, 2016, 07:37:13 pm »
There are special pens available with which you can redraw the broken lines.
http://nl.farnell.com/chemtronics/cw2900/flex-conductive-pen/dp/1663188
Ridiculously expensive stuff, but it works.
Tell us what problem you want to solve, not what solution you're having problems with
  • Country: si
    • Frenki.net
« Reply #7 on: August 01, 2016, 07:51:30 pm »
Thank you guys!
I have just ordered a few of these:
https://m.aliexpress.com/search.htm?keywords=silver%20conductive%20glue&sortType=TC_D&shippingCountry=SI&viewtype=1
I will put bare copper wire over the crack on each line and glue it with this silver glue.
That should conduct ok.
Then I'll put a blob of epoxy on the top and bottom for better strength.
The cable is only moved when opening the case so hopefuly it will last.
Tnx again.
