Welcome,
Guest
. Please
login
or
register
Did you miss your
activation email
1 Hour
1 Day
1 Week
1 Month
Forever
This topic
This board
Entire forum
Google
Bing
Home
Help
Search
About us
Links
Login
Register
Electronics
Repair
Strange problem? Bad ground?
« previous
next »
Print
Search
Pages: [
1
Go Down
Author
Topic: Strange problem? Bad ground? (Read 1585 times)
biotron345
Contributor
Country:
on:
May 09, 2016, 01:08:03 pm »
Hi all!
I've built a simple LFO for my modular synth based on an LM741. Works well except when I move my hand near it the LFO speed rises very slightly. I assume the is a bad ground? Any advice would be great!
Logged
voltz
Frequent Contributor
Country:
Re: Strange problem? Bad ground?
Reply #1 on:
May 09, 2016, 01:28:39 pm »
The circuit is such that the impedance at the 741 inputs will be quite high, therefor sensitive to external fields.
Without wanting to change the design, i would make sure the Pot case is earthed. Failing that, put the whole thing in a metal box.
Logged
biotron345
Contributor
Country:
Reply #2 on:
May 09, 2016, 01:33:03 pm »
Thanks Voltz! Are the any minor changes I could make?
Logged
voltz
Country:
Reply #3 on:
May 09, 2016, 01:40:09 pm »
Well, by decreasing both resistor values while increasing the capacitor value to keep the time constant right while at the same time reducing input impedance. But try the earthing first.
Logged
biotron345
Contributor
Country:
Reply #4 on:
May 09, 2016, 02:39:10 pm »
Will do, many thanks!!!!
Logged
biotron345
Contributor
Country:
Reply #5 on:
May 10, 2016, 09:19:45 am »
Redesigned!!!!
Logged
Print
Search
Pages: [
1
Go Up
« previous
next »
Electronics
Repair
Thanking...
EEVblog Main Site
EEVblog on Youtube
EEVblog on Twitter
EEVblog on Facebook
EEVblog on Odysee
