Hello,
I encountered a strange problem on a Korad KA3005 power supply.
Without any load, I can adjust the voltage from 0 to 31V without any problem (controlled with a DMM).
But as soon as I exceeded a 50mA load at low voltage ( 5V ), the power supply went into OCP even if the setting was 100mA or 1A.
I wanted to take apart the power supply and I measured the output transistors ( D1047 ) and the driver ( D880 ). Everything was fine, idem for the 1n4007 diode.
I reassembled everything and I still have the same problem.
As a test I use a 10mm 100mA LED, set the power supply to 5V 100mA but the power supply regulates well at 100mA for less than a second then only between 50 and 60mA.
And now comes the strange part :
I connected an electronic load to my power supply and I had exactly the same problem as with the LED.
Just by curiosity I tried with a higher voltage and current ( 15V 1A ) and....and everything worked perfectly strangely
So I retested at 5V 100mA and now everything is working again
I touched all the cables a bit to reproduce the problem but without success.
Has anyone ever had this problem?
If not, do you know where it can come from ?
As everything is working now, it's complicated to find the origin of the problem.
I am afraid that this could happen to me again so I would like to know where it could come from and change some components to prevent it.
Do you think it could come from the TL082 for the current measurement ? from the power transistors ?
Something else?
Thank you for your help
