First of all, thanks fzabkar, I thought that is what it is but wanted to be sure.
Tim, it is just the one board, this a small module (you can Google Whelen talon) that fits in your hand that weighs no more then a couple of kilos, if that.
It powers two LED modules. Strobe is more the generic term in my industry. What I mean by 1+ is I can confirm at least 2 layers. On the backside is mostly ground with a positive trace going to LED circuit B. Simply put, the 12V goes into a "section" that does whatever to it (appears to be pattern and sync controlling) then it 2 outputs lead to each specific LED circuit, shown above, then outed to its respective LED module. Metal box, (unless basic aluminum foil inside but even then the components definitely get warm), is undesirable due to asthetics, and the need for high visibility.
I am currently going to try the line filter option and see how it goes. The audible and the RF noise are mostly likely in each LED circuit, as they make different noises depending on which LED is active. (LED refers to a six string LED module)
Any other suggestions please post!
Thanks!
