Drill it out to 3x the lead diameter and clean the top solder resist back then solder a few thin wire strands through the hole, leaving room for the lead of the capacitor. Then place the cap through and solder the bottom in, the solder will wick up the wires and make an eyelet. Otherwise the drill hole next to it and place a jumper is the best bet, if there is place for it. Solder the jumper wire to the capacitor lead after making an eyelet loop in it to hold the lead.
