randomly replacing parts is not the way to go. since you have the full unregulated DC voltage on the output, my guess is that the series transistor got fried; the burned resistor is just a by-problem
my guess too is that it is a Korad-like PSU, so you should find quite a bunch of references here in the forum.
for the very first I'd check the transistors
