I bought a Sunko 788H in early 2016 and the first one just blew fuses so I exchanged it for another and it would blow the circuit breaker quite often. It is a 120VAC version and suffers from severe in
rush current as the high current transformer has two windings in parallel and initially looks like a dead short until the flux builds up and increases the primary impedance. Finally after making a 15 cell NIMH battery pack the TRIAC blew up. I replaced it with higher current capability BTA41 41 amp unit and it blew up two of these when turning on power. I bit the bullet and added in rush current limiting and other mods as described in the attached PDF I generated. It works better than ever now and just purrs like a kitten! The PDF shows what I did. I cobbled together the modifications from parts I have in my lab. I put the TRIAC on the back of the PCB on a bigger heat sink and added a cooling fan, new knobs that actually fit the pot shafts, replaced the fuse holder and it is all mo betta. In my testing I used a variac to an isolation transformer so I could hook my expensive equipment up to this dangerous beast and made sure no potentials nor currents could flow between my equipment ground and this unknown design. I wish you could get the schematics but I have found nothing on the net. There are many ways to do what I did. I just used what I had. If you attempt this modification be very careful!!! Let me know if any one wants more info.
