Those are too destructive ways to crack it apart. There are different ways to open nicely. You can put in it a freezer, then take out and quickly (like within 30 seconds) hit with a rubber mallet all around the weld. Freezing temperatures make the weld fragile. Be sure to put it on some hard surface, holding in hand while doing so will likely result in a broken inductor or transformer. Also there is a chemical way. Special solvent mixtures do exist but gasoline, nitro solvents and acetone work too AFAIK, not as well though. And may leave marks on plastic. Usually solvent is applied across the weld, left for around 5-10 minutes and cracked apart with a little bit of force.
