Switching power supply failed. It is 25.4V 6A unit out of some telecom equipment. Two primary drive transistors to the HF transformer are shorted. They are 2SC2625. Everything else seems fine. I repair a lot of power equipment with FETs. I will often power up the units without the transistors installed to verify that the gate drives are good before replacing the transistors. But these are bipolar NPNs so I know I am dealing with a current not a voltage. When I put my isolated scope probes on the base to emitter I am getting alternating push-pull spikes from 0 to 6 volts at 24 khz. Voltage might be ok (transistors are not installed) but the frequency seems low. Buss voltage is 360 volts so I think it should run a lot faster. Is there a better way to check this? Should I just throw some transistors in and try it?
