Author Topic: Symmetricom NTS-200 Time Server  (Read 21591 times)
Offline anenni
Re: Symmetricom NTS-200 Time Server
« Reply #25 on: January 02, 2020, 11:53:46 am »
We have one that reset to year 2000 just on midnight between December 24 and 25...  |O
UTC Time:    15:22:09
UTC Date:    05/15/2000
We have a quite old 8.0 firmware dating back to 2003
General
Bootloader:    182-9003v008
Software Build:    182-9004v008
File System Version:    182-9005v008
I found out on some forums that many were updated to 8.2 and some to 8.4 firmware, but files are unavailable.
Instead on microsemi extranet under login there's a 2008 update, but with no instructions and a weird bin file name inside the archive:
Title   Description   Date
NTS-200 (1.81)
Software to upgrade the NTS-200 to 1.81
   10/30/2008
182-9004v8[1].4ckpt1.81.zip
Offline b0bd
« Reply #26 on: January 02, 2020, 01:55:54 pm »
anenni,
can you give me more details of where to get that file? do you need a login? I've flashed the NTS-200 before so this is quite hopeful
Offline anenni
« Reply #27 on: January 02, 2020, 02:32:50 pm »
You just have to register on microsemi to time sync systems here:
https://my.microsemi.com/AWelcome/HomeRNew.aspx
Inside the zip there's only a single .bin file with the same name with square brackets, that seems weird, and no instrucrions at all.
Old update instructions I found report other 2 files with extensions .fs and .bt
ftp://anthonygregory.com/Upgrade%20to%20Firmware%20Version%208.x.pdf
Offline b0bd
« Reply #28 on: January 02, 2020, 02:39:58 pm »
looking at your instructions, I'd just burn the .bin using the instructions you supplied above:
>f100 bh <FTP IP Address> <Filename>.bin
Burn host is ready!!!
>f100 bu (Note: enter “bu”, not “bub”)
and skip the
>f100 bh <FTP IP Address> <Filename>.bt
>f100 bub
and
>f100 bh <FTP IP Address> <Filename>.fs
>f100 bf
parts.
since its not working anyway, not much to lose
Offline anenni
« Reply #29 on: January 02, 2020, 02:53:58 pm »
I thought of just skipping the other files, but the bin long file name with square brackets and 3 dots worries me a bit for ftp transfer and old filesystem naming limits.
182-9004v8[1].4ckpt1.81.bin
I opened a case and waiting.
If you want to experiment please post results. :)
Offline anenni
« Reply #30 on: January 02, 2020, 03:34:00 pm »
There are a lot of microsemi/simmetrix with rollover date issues
Table 2 Discontinued Products
For the products listed in Table 3, These are Obsolete and unsupported products not affected
by the April 7th, 2019 GPS rollover event. Internal rollover is unknown for some. Please refer to
note column.
Table 3 Obsolete Products
Product Line Descriptions
Affected Part
Numbers
Internal
Rollover Date
Notes
Timesource TS3x00
090-72010-0x
090-72020-0x
090-72050-0x
090-72060-0x
10/21/2018 reference FSB 098-40621-95 for recommended action
TP 5000 IMC Card w/ Integrated GPS 090-50331-01 9/18/2022
TP5000 IMC Card w/integrated GPS &
exp cntl
090-50331-02 9/18/2022
9/18/2022 GPS input
2030 GNSS input
TP100 TP100 MODULE 090-95000-01 9/18/2022
SyncServer 100 1520R-S100 (-xx) 9/18/2022
SyncServer 200/250
1520-S200 (-xx)
1520R-S200 (-xx)
1520-S250 (-xx)
1520R-S250 (-xx)
9/18/2022
SyncServer 300/350
1520-S300 (-xx)
1520R-S300 (-xx)
1520-S350 (-xx)
1520R-S350 (-xx)
9/18/2022
XL GPS 1530-602-1 2026
9/18/2022 with GPS option module 87-8028-2 (Use Function 119 to verify receiver card)
4/7/2019 with GPS option module 86-8013 (Use Function 119 to verify receiver card)
SyncServer
TimeProvider 5000
TP5000 IMC Card w/dual GPS & exp cntl 090-50331-05
GPS receivers
XLi w/gps receiver 1510-6x2-xxx
Offline anenni
« Reply #31 on: January 02, 2020, 03:36:14 pm »
and more , see attached file
Product Line Descriptions Part Numbers
Internal
Rollover Date
Notes
bc11603-3001 unk If brought to last released EEPROM version per FSB 098-50620-77
TTM637VME-xxxx unk If brought to last released EEPROM version per FSB 098-50620-76
BC637PCI-U unk If updated to version 14 per FSB 098-50620-036
XL AK XL-AK _151-60x unk Need to set Function 68 w/correct(2011) year info
XL-DC Xl-DC_151-6x2 unk Need to set Function 68 w/correct(2011) year info
ET60x0 ET60x0 unk
56000 Data Rate Clock 56K_560-5308-x unk
TS2100-xxxx TS2100 2015 Rolled in 2015 reference - FSB 098-50620-81
9/16/2018 product shipped through 2004
9/18/2022 product shipped from 2005
OEM Module GPS Timing Antenna
58534A
58534-H01
GPS receivers
Bus Cards Time & Freq proc
Offline b0bd
« Reply #32 on: January 02, 2020, 04:17:09 pm »
Ok, I got it to take the file, unfortunately no life extension for me:
UTC Time   (UTC) 16:14:18
UTC Date   (UTC) 05/18/2000
Pending Leap
Second Correction   NONE
I simply renamed the bin file to 182-9004v8.bin
>f100 bh 172.31.90.132 pub/182-9004v8.bin
>f100 bu
Are you sure(y/N)?y
Burning Prog1
file: 182-9004v8.bin has NTS-200 :7
Burning file 182-9004v8.bin with size 697140 to partition:1 sector:6
Sec: 6 re: 0
Sec: 7 re: 0
Sec: 8 re: 0
Sec: 9 re: 0
Sec: 10 re: 0
Sec: 11 re: 0
Sec: 12 re: 0
Sec: 13 re: 0
Sec: 14 re: 0
Sec: 15 re: 0
Sec: 16 re: 0
Flash successfully programmed CRC32 = 0x1E2E818
>F100 K I L L
Are you sure(y/N)?y
>Connection closed by foreign host.
>f100 ver
f100 VER
 BOOTLOADER  182-9003v8.4
 SOFTWARE    182-9004v8.4
 FILE SYSTEM 182-9005v8.4
 NVRAM VER   2
Offline anenni
« Reply #33 on: January 02, 2020, 04:25:39 pm »
Could you post the output of the command "f100 ver" to see the other files versions?
Offline anenni
« Reply #34 on: January 02, 2020, 04:32:13 pm »
Mine is:
But I found some having at least 2 items updated, so maybe there's a prerequisite version for updating just the bin file to the latest 2008 version.
182-9004v8.2
182-9005v8.2
Offline anenni
« Reply #35 on: January 02, 2020, 04:34:58 pm »
Didn't notice it was scrollable.
So you have:
 NVRAM VER   2
But after a correct update at least the second item should change....
Do you have by chance the old 8.4 update?
Offline b0bd
« Reply #36 on: January 02, 2020, 04:56:03 pm »
sorry, I don't have it, I did look  |O
Offline anenni
« Reply #37 on: January 02, 2020, 05:03:47 pm »
neither the previous 8.2?
Offline anenni
« Reply #38 on: January 02, 2020, 05:21:26 pm »
By the way I'm not able to update that way:
>f100 ver
f100 VER
 BOOTLOADER  182-9003v008
 SOFTWARE    182-9004v008
 FILE SYSTEM 182-9005v008
 NVRAM VER   2
>f100 bh 172.16.11.24 182-9004v8.bin
>f100 bu
Are you sure(y/N)?y
Burning Prog1
Can't open file: 182-9004v8.bin
Wrong File type
Offline anenni
« Reply #39 on: January 02, 2020, 05:36:29 pm »
Maybe without the bootloader update you can't update the software.
And maybe you succeeded in writing the file because it's the same latest release v8.4 you already had.
Offline b0bd
« Reply #40 on: January 02, 2020, 09:08:41 pm »
Burning Prog1
Wrong File type
make sure your ftp is set up for anonymous ftp. I fought through an hour of this. Ignore the 'wrong file type' and focus on the 'cant open file'
Offline anenni
« Reply #41 on: January 03, 2020, 07:07:36 pm »
What a misleading error message.  :-\
I checked anonymous was working, but the file had permission problems.
thank you.
Now I succeded and the system updated from v8.0 v8.4, and it updated all three itmes with the single bin file, but copyright year passed only from 2002 to 2003, changing company from truetime to Symmetricom
year 2008 from the microsemi file description was nowhere, and after the update gps date remained indentically wrong.
they didn't even change truetime brand and copyright date on the web interface
Welcome to TrueTime Network Interface
User name: operator
password: *******
Network Interface 182-9004v008  (c) 1998 - 2002 TrueTime Inc.
All Rights Reserved
Login successful
> f100 bh 172.16.11.24 pub/182-9004v8.bin
> f100 bu
Are you sure(y/N)?y
Burning Prog1
Sec: 6 re: 0
Sec: 7 re: 0
Sec: 8 re: 0
Sec: 9 re: 0
Sec: 10 re: 0
Sec: 11 re: 0
Sec: 12 re: 0
Sec: 13 re: 0
Sec: 14 re: 0
Sec: 15 re: 0
Sec: 16 re: 0
> f100 K I L L
Are you sure(y/N)?y
Welcome to Symmetricom Network Interface
User name: operator
password: *******
Network Interface 182-9004v8.4  (c) 1998 - 2003 Symmetricom Inc.
All Rights Reserved
Login successful
> f100 ver
f100 VER
 NVRAM VER   2
 SER NUM     024029586
Offline InFoq
« Reply #42 on: January 09, 2020, 09:34:19 am »
Would anyone happen to know if inside the NTS-200 there might be a PPS (Pulse per second) test-point signal somewhere?  (even if mine is giving the wrong 2000 date as NTP server, at least I might get some value out of using it for accurate time-span measurement?)  thanx
Offline b0bd
« Reply #43 on: January 09, 2020, 03:53:31 pm »
I opened it up to have a look at that kind of possibility. It uses a Zarlink GP2021 GPS Correlator, and data sheets are readily available on the Internet.  I don't have an oscilloscope to probe the likely pins for a PPS signal though, so I just ordered a ublox GPS module and going to build a Raspberry Pi time source instead.
The following users thanked this post: InFoq
Offline anenni
« Reply #44 on: January 09, 2020, 09:14:32 pm »
I'm wondering if a linux ntpd or other daemon between nts200 and clients can correct the gps epoch correctly.
I read that there is such possibility with gpsd through a serial or usb port GPS.
Offline smgvbest
    • Kilbourne Astronomics
« Reply #45 on: January 12, 2020, 04:03:39 am »
I"ve just started playing with this also and have a ebay unit coming soon
it says in the listing
 SER NUM     SRNO:032840810
I tried creating an account but it says "The Resource you are trying to access requires an Active Support Contract"
can some one post the zip here
I'd like to look at it and see if there is a chance to hack it
the other think will be to read out the various memorys and try to hack it directly
Sandra
(Yes, I am a Woman :p )
Offline gregorysch
« Reply #46 on: January 13, 2020, 01:00:20 pm »
Hello,
I have got also a NTS-200. Is it possible that someone post the firmware in this forum?
I created an account on Microsemi and requested the access but I didn't received any feedback.
Thanks a lot,
Greg.
Offline SoundTech-LG
« Reply #47 on: January 13, 2020, 04:01:46 pm »
Well at least they can spam you now. Thank you Microsemi er... Microchip !!! :--
Offline aol
« Reply #48 on: January 15, 2020, 08:52:18 am »
Hello,
does anyone have the fs file? I have made a stupid thing, and my fs contains now bin partition.
Thank you
Offline InFoq
« Reply #49 on: January 22, 2020, 11:55:27 pm »
... Zarlink GP2021 GPS Correlator, and data sheets are readily available on the Internet.  I don't have an oscilloscope to...
On the front bottom left of the front panel, there seems to be a flashing PPS green LED.  Oscillopscope measurements seems to show that LED pulse is tracking my Adafruit PA6H GPS module's PPS but is creeping slowly between 5.2 ms to 0.7 ms behind the PA6H, but I am not sure which GPS is more accurate.  Anyone else been able to confirm the accuracy of this LED as potential NTS-200 1 PPS signal?  Thanks
« Last Edit: January 24, 2020, 06:51:16 am by InFoq »
