Just for a FYI
I ran the bin file thru binwalk and we can see these
root@kali:~/Downloads# binwalk '182-9004v8[1].4ckpt1.81.bin'
DECIMAL HEXADECIMAL DESCRIPTION
24 0x18 Copyright string: "Copyright 1999 TrueTime Inc. and Wind River Systems, Inc."
22960 0x59B0 Copyright string: "Copyright 1984-1996 Wind River Systems, Inc."
23553 0x5C01 Zlib compressed data, default compression
i extracted the zlib file
dd if=182-9004v8.4ckpt1.81.bin skip=23553 bs=1 of=23553.zz
decompressed it
unpigz 23553.zz
root@kali:~/Downloads# binwalk 23553
303148 0x4A02C HTML document header
304687 0x4A62F HTML document footer
307184 0x4AFF0 HTML document header
307591 0x4B187 HTML document footer
1443260 0x1605BC VxWorks WIND kernel version "2.5"
1456188 0x16383C Copyright string: "Copyright Wind River Systems, Inc., 1984-1999"
1461152 0x164BA0 HTML document header
1561621 0x17D415 Copyright string: "copyright_wind_river"
1622016 0x18C000 Copyright string: "Copyright 1984-1996 Wind River Systems, Inc."
1640900 0x1909C4 VxWorks symbol table, big endian, first entry: [type: function, code address: 0x789B0200, symbol address: 0x4C3F1800]
looked at some strings
/config/acts.conf
/etc/ntp.conf
/etc/ntp.keys
/ramdrv/ntp.log
/config/snmp.conf
/config/truetime.conf
/web/data/IndexPg.dat
/web/data/ControlPg.dat
/web/data/TimePg.dat
/web/data/TimeContPg.dat
/web/data/NetworkPg.dat
/web/data/NetContPg.dat
/web/data/SatPg.dat
/web/data/SatContPg.dat
/web/data/GpsPg.dat
/web/data/GpsContPg.dat
/web/data/ActsPg.dat
/web/data/ActsContPg.dat
/web/data/ActsConfPg.dat
/web/data/NtpConfPg.dat
/web/data/Md5ConfPg.dat
/web/data/SnmpConfPg.dat
/web/data/NtpLogPg.dat
ntp-4.0.94
ARM PID - ARM7TDMI (ARM)
Osicom NET+ARM Ethernet driver
Jun 20 2008, 14:46:00
WIND version 2.5
]]]]]]]]]]]]]]]]]]]]]]]]]]]]] Development System
]]]]]]]]]]] ]]]] ]]]]]]]]]] ]] ]]]] (R)
]]]]]]]]]]]]]]]]]]]]]]]]]]] VxWorks version
]]]]]]]]]]]]]]]]]]]]]]]]]] KERNEL:
]]]]]]]]]]]]]]]]]]]]]]]]] Copyright Wind River Systems, Inc., 1984-1999
spy not configured into this system.
/bin/ls -a %s
/bin/rm %s
cat: read error: Is a directory
/bin/cat < %s
/bin/cat > %s
IP 4.4 TCP/IP
IP 4.4 ARP
xWorks (%s) FTP server ready
Local resource failure: %s
Directory non existent or syntax error
Data connection error
Parameter not accepted
Can't open passive connection
HELP USER PASS QUIT LIST NLST
RETR STOR CWD TYPE PORT PWD
STRU MODE ALLO ACCT PASV NOOP
VxWorks login:
This program contains confidential information of Wind River Systems, Inc.
and disclosure and copying are prohibited.
