Author Topic: Symmetricom NTS-200 Time Server  (Read 21586 times)
Offline ibjeepin
Re: Symmetricom NTS-200 Time Server
« Reply #50 on: January 24, 2020, 05:17:00 pm »
You just have to register on microsemi to time sync systems here:
https://my.microsemi.com/AWelcome/HomeRNew.aspx
Inside the zip there's only a single .bin file with the same name with square brackets, that seems weird, and no instrucrions at all.
Old update instructions I found report other 2 files with extensions .fs and .bt
ftp://anthonygregory.com/Upgrade%20to%20Firmware%20Version%208.x.pdf
anenni, how did you get access to the file as it seems like its locked on the microsemi site.
Offline smgvbest
    • Kilbourne Astronomics
« Reply #51 on: January 27, 2020, 01:32:44 am »
register on the website then try to download the file.
it will tell you that you need approval, complete the request.
they completed mine in a few days.
I do have the files you get attached
Sandra
(Yes, I am a Woman :p )
Offline smgvbest
« Reply #52 on: January 27, 2020, 04:33:54 am »
Just for a FYI
I ran the bin file thru binwalk and we can see these
root@kali:~/Downloads# binwalk '182-9004v8[1].4ckpt1.81.bin'
DECIMAL       HEXADECIMAL     DESCRIPTION
24            0x18            Copyright string: "Copyright 1999 TrueTime Inc. and Wind River Systems, Inc."
22960         0x59B0          Copyright string: "Copyright 1984-1996 Wind River Systems, Inc."
23553         0x5C01          Zlib compressed data, default compression
i extracted the zlib file
dd if=182-9004v8.4ckpt1.81.bin skip=23553 bs=1 of=23553.zz
decompressed it
unpigz 23553.zz
root@kali:~/Downloads# binwalk 23553
303148        0x4A02C         HTML document header
304687        0x4A62F         HTML document footer
307184        0x4AFF0         HTML document header
307591        0x4B187         HTML document footer
1443260       0x1605BC        VxWorks WIND kernel version "2.5"
1456188       0x16383C        Copyright string: "Copyright Wind River Systems, Inc., 1984-1999"
1461152       0x164BA0        HTML document header
1561621       0x17D415        Copyright string: "copyright_wind_river"
1622016       0x18C000        Copyright string: "Copyright 1984-1996 Wind River Systems, Inc."
1640900       0x1909C4        VxWorks symbol table, big endian, first entry: [type: function, code address: 0x789B0200, symbol address: 0x4C3F1800]
looked at some strings
/config/acts.conf
/etc/ntp.conf
/etc/ntp.keys
/ramdrv/ntp.log
/config/snmp.conf
/config/truetime.conf
/web/data/IndexPg.dat
/web/data/ControlPg.dat
/web/data/TimePg.dat
/web/data/TimeContPg.dat
/web/data/NetworkPg.dat
/web/data/NetContPg.dat
/web/data/SatPg.dat
/web/data/SatContPg.dat
/web/data/GpsPg.dat
/web/data/GpsContPg.dat
/web/data/ActsPg.dat
/web/data/ActsContPg.dat
/web/data/ActsConfPg.dat
/web/data/NtpConfPg.dat
/web/data/Md5ConfPg.dat
/web/data/SnmpConfPg.dat
/web/data/NtpLogPg.dat
ntp-4.0.94
ARM PID - ARM7TDMI (ARM)
Osicom NET+ARM Ethernet driver
Jun 20 2008, 14:46:00
WIND version 2.5
]]]]]]]]]]]]]]]]]]]]]]]]]]]]]       Development System
     ]]]]]]]]]]]  ]]]]     ]]]]]]]]]]       ]]              ]]]]         (R)
]]]]]]]]]]]]]]]]]]]]]]]]]]]       VxWorks version
]]]]]]]]]]]]]]]]]]]]]]]]]]       KERNEL:
]]]]]]]]]]]]]]]]]]]]]]]]]       Copyright Wind River Systems, Inc., 1984-1999
spy not configured into this system.
/bin/ls -a %s
/bin/rm %s
cat: read error: Is a directory
/bin/cat < %s
/bin/cat > %s
IP 4.4 TCP/IP
IP 4.4 ARP
xWorks (%s) FTP server ready
Local resource failure: %s
Directory non existent or syntax error
Data connection error
Parameter not accepted
Can't open passive connection
HELP    USER    PASS    QUIT    LIST    NLST
RETR    STOR    CWD     TYPE    PORT    PWD
STRU    MODE    ALLO    ACCT    PASV    NOOP
VxWorks login:
This program contains confidential information of Wind River Systems, Inc.
and disclosure and copying are prohibited.
Sandra
Offline smgvbest
« Reply #53 on: January 27, 2020, 04:59:47 am »
Does any one have all the update files for any version of of the NTS-200?
looks like there should be atleast 3
bootloader
filesystem
and the main program
might help figuring more out
I would really like the filesystem one.  a look at etc/passwd would help and more importantly removing passwords from accounts where we don't know the passwords i think would be helpfull
Sandra
Offline smgvbest
« Reply #54 on: January 27, 2020, 06:27:16 am »
Adding a little more information here
the GPS systems in the NTS-200 is the
GP2015/GP2021 and P60ARM
The GP2015 (RF Frontend) & GP2021(GPS 12 channel Correlator) process the GPS signal and pass it to the P60ARM (ARM Processor)
the 1 PPS should be available on pin (32, 68 or 80 of the GP2021) depending on how the registers are setup.
Will track down where this is available later.
It also looks like the J11 connector is the JTAG connector for the P60ARM (Pins 67-71)
Will figure out pin out later.
my un-educated guess at this point is the code in the P60ARM is probably where any patch would occur
attached are datasheets for the 3 component mentioned as well as
photo's of the components
GP2015
915474-0
GP2021
915478-1
P60ARM
915486-2
« Last Edit: January 27, 2020, 06:36:33 am by smgvbest »
Sandra
Offline smgvbest
« Reply #55 on: January 27, 2020, 06:34:17 am »
Ran out of attachment room,  here's the datasheets
Sandra
Offline composerjk
« Reply #56 on: January 27, 2020, 05:34:40 pm »
Attached is a tar of the prior version 8.2 firmware files for the TrueTime NTS-200 from 2004. Hope they help. I may have at least a version before that, if helpful. [Updated the tar file to include the release notes and upgrade document.]
« Last Edit: January 27, 2020, 06:23:39 pm by composerjk »
Jeff—Typeface designer, Musician, Dancer, System Architect
https://1403.slantedhall.com/ | https://slantedhall.com/
The following users thanked this post: smgvbest
Offline InFoq
« Reply #57 on: January 28, 2020, 12:38:56 am »
...the 1 PPS should be available on pin (32, 68 or 80 of the GP2021) depending on how the registers are setup. Will track...
after satellite acquisition, I attempted to oscilloscope pins 1,32,68 and 80, but did not seem to get anything close to a 1 PPS signal with my existing firmware.  Wonder how the front panel green flashing LED is derived...
« Last Edit: January 28, 2020, 01:21:08 am by InFoq »
Offline fira4
  • Country: id
« Reply #58 on: January 28, 2020, 11:30:58 pm »
after successful upgrade  , date time still set to 2000, how to fix the time
>F100 VER
F100 VER
 BOOTLOADER  182-9003v8.4
 SOFTWARE    182-9004v8.4
 FILE SYSTEM 182-9005v8.4
 NVRAM VER   2
 SER NUM     044550681
>F03
F03 UTC 6/13/2000 23:29:49
Offline smgvbest
« Reply #59 on: January 29, 2020, 02:36:10 am »
i'll take a look at this and see if there's anything extra interesting
Sandra
Offline smgvbest
« Reply #60 on: January 29, 2020, 02:57:57 am »
so looking and reading more on this it's not going to a application firmware fix it's going to be the firmware shared by the GP2021/P60ARM   they share SRAM and EPROM   the GP2022 is the memory controler for the P60ARM if i read things correctly
that being case and this being the GPS WNRO issue where the Week Number is a 10bit value upto 1024 weeks what we have to find int he P60ARM code is where doe it calucate the week number of offset by the latest week number.
They followed the dev system pretty much to a tee which helps.  based on this the U39/U40 are the EPROMs and U19/U21 are the SRAM used by the GP2022/P60ARM  and U22 may be the EEPROM from the memory map but not shown in the block diagram (this is only a guess until I open it p again)
see attached app note on that and datasheet for the EPROM (need to verify though)
Oh, Pin80 of the GP2021 is an INPUT not an output
* an4855.pdf (793.11 kB - downloaded 211 times.)
Sandra
The following users thanked this post: fira4, InFoq, ibjeepin
Offline fira4
  • Country: id
« Reply #61 on: February 04, 2020, 04:17:15 am »
so there is no way to fix nts-200 ?
Offline smgvbest
« Reply #62 on: February 05, 2020, 01:14:45 am »
don't know yet,   I'm going to get dumps of the P60ARM EPROMs and take a look but I'm not a developer.
I'll publish what I find here and maybe others will take interest and help
Sandra
The following users thanked this post: ibjeepin
Offline ibjeepin
« Reply #63 on: February 07, 2020, 11:11:16 am »
Sandra, thanks for putting in your time and brain into this problem. I know i dont have the energy to do this.
Offline smgvbest
« Reply #64 on: February 08, 2020, 09:36:39 pm »
My thought/hope is I can fine where the GPS Week value is read in and basically add 1024 to it and see if that works.  if so that would buy another 19+ years
if not I read one way is to find where the base date is stored
The first GPS Date was January 6, 1980  and the first rollover was midnight August 21, 1999 so I am hoping to find the August date somewhere in the firmware
if that can be changed April 6, 2019 that might also fix it.  but I'm truthfully not sure what I'll be able to figure out on this
this is me just saving some links I found that I thought might be helpful
http://gnsstk.sourceforge.net/gps_8c-source.html#l00714
http://www.telesens.co/2017/07/17/calculating-position-from-raw-gps-data/#Processing_Raw_GPS_Data
https://www.unoosa.org/documents/pdf/icg/2018/ait-gnss/15a_PPP_RTKLIB.pdf
https://www.gps.gov/technical/ps/1995-SPS-signal-specification.pdf
https://sourceforge.net/projects/gnss-sdr/
http://en.qi-hardware.com/wiki/GPS_Free_Stack
http://www.rtklib.com/
https://gogps-project.github.io/
https://www.use-snip.com/kb/article-categories/message-decoding/
https://www.gps.gov/technical/icwg/IS-GPS-200H.pdf
For reference Subframe 1-3 structure
                           SUBFRAME1
TERM,               NR BITS,    BITS NO PARITY,   BITS WITH PARITY
preamble,           8,          1-8,              1-8,
TLM,                14,         9-22,             9-22
reserved,           2,          23-24,            23-24
--PARITY--          6,          -----             25-30
TOW,                17,         25-41,            31-47
alert_flag,         1,          42,               48
anti_spoof_flag,    1,          43,               49
subframeID,         3,          44-46,            50-52
parity_related,     2,          47-48,            53-54
week,               10,         49-58,            61-70
code_on_L2,         2,          59,60,            71-72
ura,                4,          61-64,            73-76
health,             6,          65-70,            77-82
iodc_MSB,           2,          71-72,            83-84
--PARITY--          6,          -----             85-90
L2_P_data_flag,     1,          73,               91
reserved,           23,         74-96,            92-114
--PARITY--          6,          -----             115-120
reserved,           24,         97-120,           121-144
reserved,           24,         121-144,          151-174
reserved,           16,         145-160,          181-196
tgd,                8,          161-168,          197-204
--PARITY--          6,          -----             205-210
iodc_LSB,           8,          169-176,          211-218
toc,                16,         177-192,          219-234
--PARITY--          6,          -----             235-240
af2,                8,          193-200,          241-248
af1,                16,         201-216,          249-264
--PARITY--          6,          -----             265-270
af0,                22,         217-238,          271-292
parity_related,     2,          239-240,          293-294
--PARITY--          6,          -----             295-300
                           SUBFRAME2
TLM,                14,         9-22,             9-22
iode,               8,          49-56,            61-68
crs,                16,         57-72,            69-84
--PARITY--          6,          -----             95-90
delta_n,            16,         73-88,            91-106
m0_MSB,             8,          89-96,            107-114
m0_LSB,             24,         97-120,           121-144
--PARITY--          6,          -----             145-150
cuc,                16,         121-136,          151-166
ecc_MSB,            8,          137-144,          167-174
--PARITY--          6,          -----             175-180
ecc_LSB,            24,         145-168,          181-204
cus,                16,         169-184,          211-226
sqrta_MSB,          8,          185-192,          227-234
sqrta_LSB,          24,         193-216,          241-264
toe,                16,         217-232,          271-286
fit_interval_flag,  1,          233,              287
age_of_data_offset, 5,          234-238,          288-292
                           SUBFRAME3
TLM,                14,         9-22,             9-22
cic,                16,         49-64,            61-76
omega0_MSB,         8,          65-72,            77-84
omega0_LSB,         24,         73-96,            91-114
cis,                16,         97-112,           121-136
i0_MSB,             8,          113-120,          137-144
i0_LSB,             24,         121-144,          151-174
crc,                16,         145-160,          181-196
w_MSB,              8,          161-168,          197-204
w_LSB,              24,         169-192,          211-234
omegadot,           24,         193-216,          241-264
iode,               8,          217-224,          271-278
idot,               14,         225-238,          279-292
Sandra
Offline smgvbest
« Reply #65 on: February 10, 2020, 01:30:30 am »
Here's the JP11 JTAG Pinout for the P60ARM Processor
924938-0
« Last Edit: February 10, 2020, 01:35:48 am by smgvbest »
Sandra
Offline smgvbest
« Reply #66 on: February 10, 2020, 01:35:03 am »
This is the full view of the P60ARM JTAG connector
924946-0
the EPROMs used for the P60ARM Processor at AT27C516  (32Kx16)  These are U39 & U40
924942-1
And their datasheet
* AT27C516.pdf (270.29 kB - downloaded 135 times.)
« Last Edit: February 10, 2020, 01:52:44 am by smgvbest »
Sandra
Offline smgvbest
« Reply #67 on: February 10, 2020, 01:37:25 am »
Here's the Full View of the Main Board front
924952-0
Sandra
Offline smgvbest
« Reply #68 on: February 10, 2020, 01:39:38 am »
Back side of the Main Board (nothing to see here except a unpopulated memory footprint
924956-0
Sandra
Offline smgvbest
« Reply #69 on: February 10, 2020, 01:44:08 am »
Next are some of the chips with labels so we know what they are
Lattice GAL16V8D @ U22
924960-0
and datasheet
* GAL16V8.pdf (761.38 kB - downloaded 57 times.)
XILINIX 1765EPC  @ U4
924966-2
and datasheet
* XC1765EPC.pdf (248.7 kB - downloaded 218 times.)
« Last Edit: February 10, 2020, 01:53:24 am by smgvbest »
Sandra
Offline smgvbest
« Reply #70 on: February 10, 2020, 01:50:01 am »
Here's another one of the Lattice chips,  the GAL22LV10C @ U15
924972-0
and it's datasheet
* GAL22LV10D.PDF (588.45 kB - downloaded 111 times.)
« Last Edit: February 10, 2020, 12:30:07 pm by smgvbest »
Sandra
Offline acfnews
« Reply #71 on: February 16, 2020, 02:37:24 pm »
Sandra (et all),
I also have a NTS-200 (on a remote site), which I'm eager to get fixed as the time on this unit is also affected by the week-rollover issue.
I will pick this unit up for some debugging on this.
Hopefully we can get this fixed, seems like a lot of people still have this unit...
Ron
Offline smgvbest
« Reply #72 on: February 18, 2020, 01:29:11 pm »
I looks like you can use a AT49F1025 to replace the EPROMs on the NTS-200.   They are pin compatible with 1 extra address line (A15) that on the AT27F516 is a NC pin.
this will make testing code changes easier as the chip can be reflashed as needed unlike the 27F516 which is OTP
Sandra
Offline smgvbest
« Reply #73 on: February 19, 2020, 12:00:12 am »
if I'm lucky I finally found the NET+40 hardware reference manual and datasheet (more of a marketing sheet)
see attached
* 73-NET-40-QIPRO-4.pdf (4343.89 kB - downloaded 114 times.)
* 93600.pdf (175.72 kB - downloaded 97 times.)
Sandra
Offline BloodyCactusTopic starter
    • Kråketær
« Reply #74 on: February 19, 2020, 03:25:33 am »
Just noticed this, from my original post my nts-200 is now toast. its weird, its rollover occured very early january I think or something. My machines started saying it was 2006 :/
I guess these things are basically paperweights now... shame.
-- Aussie living in the USA --
