My thought/hope is I can fine where the GPS Week value is read in and basically add 1024 to it and see if that works. if so that would buy another 19+ years
if not I read one way is to find where the base date is stored
The first GPS Date was January 6, 1980 and the first rollover was midnight August 21, 1999 so I am hoping to find the August date somewhere in the firmware
if that can be changed April 6, 2019 that might also fix it. but I'm truthfully not sure what I'll be able to figure out on this
this is me just saving some links I found that I thought might be helpful
http://gnsstk.sourceforge.net/gps_8c-source.html#l00714http://www.telesens.co/2017/07/17/calculating-position-from-raw-gps-data/#Processing_Raw_GPS_Datahttps://www.unoosa.org/documents/pdf/icg/2018/ait-gnss/15a_PPP_RTKLIB.pdfhttps://www.gps.gov/technical/ps/1995-SPS-signal-specification.pdfhttps://sourceforge.net/projects/gnss-sdr/http://en.qi-hardware.com/wiki/GPS_Free_Stackhttp://www.rtklib.com/https://www.gps.gov/https://gogps-project.github.io/https://www.use-snip.com/kb/article-categories/message-decoding/https://www.gps.gov/technical/icwg/IS-GPS-200H.pdfFor reference Subframe 1-3 structure
SUBFRAME1
TERM, NR BITS, BITS NO PARITY, BITS WITH PARITY
preamble, 8, 1-8, 1-8,
TLM, 14, 9-22, 9-22
reserved, 2, 23-24, 23-24
--PARITY-- 6, ----- 25-30
TOW, 17, 25-41, 31-47
alert_flag, 1, 42, 48
anti_spoof_flag, 1, 43, 49
subframeID, 3, 44-46, 50-52
parity_related, 2, 47-48, 53-54
week, 10, 49-58, 61-70
code_on_L2, 2, 59,60, 71-72
ura, 4, 61-64, 73-76
health, 6, 65-70, 77-82
iodc_MSB, 2, 71-72, 83-84
--PARITY-- 6, ----- 85-90
L2_P_data_flag, 1, 73, 91
reserved, 23, 74-96, 92-114
--PARITY-- 6, ----- 115-120
reserved, 24, 97-120, 121-144
reserved, 24, 121-144, 151-174
reserved, 16, 145-160, 181-196
tgd, 8, 161-168, 197-204
--PARITY-- 6, ----- 205-210
iodc_LSB, 8, 169-176, 211-218
toc, 16, 177-192, 219-234
--PARITY-- 6, ----- 235-240
af2, 8, 193-200, 241-248
af1, 16, 201-216, 249-264
--PARITY-- 6, ----- 265-270
af0, 22, 217-238, 271-292
parity_related, 2, 239-240, 293-294
--PARITY-- 6, ----- 295-300
SUBFRAME2
TLM, 14, 9-22, 9-22
iode, 8, 49-56, 61-68
crs, 16, 57-72, 69-84
--PARITY-- 6, ----- 95-90
delta_n, 16, 73-88, 91-106
m0_MSB, 8, 89-96, 107-114
m0_LSB, 24, 97-120, 121-144
--PARITY-- 6, ----- 145-150
cuc, 16, 121-136, 151-166
ecc_MSB, 8, 137-144, 167-174
--PARITY-- 6, ----- 175-180
ecc_LSB, 24, 145-168, 181-204
cus, 16, 169-184, 211-226
sqrta_MSB, 8, 185-192, 227-234
sqrta_LSB, 24, 193-216, 241-264
toe, 16, 217-232, 271-286
fit_interval_flag, 1, 233, 287
age_of_data_offset, 5, 234-238, 288-292
SUBFRAME3
TLM, 14, 9-22, 9-22
cic, 16, 49-64, 61-76
omega0_MSB, 8, 65-72, 77-84
omega0_LSB, 24, 73-96, 91-114
cis, 16, 97-112, 121-136
i0_MSB, 8, 113-120, 137-144
i0_LSB, 24, 121-144, 151-174
crc, 16, 145-160, 181-196
w_MSB, 8, 161-168, 197-204
w_LSB, 24, 169-192, 211-234
omegadot, 24, 193-216, 241-264
iode, 8, 217-224, 271-278
idot, 14, 225-238, 279-292
