I accidentally touched the Tx and/or Rx pins of my X72 to the +23 V supply I was using -- the Tx output is stuck at +23 V now. The rest of the oscillator works (and I can use the EFC to adjust the frequency), but now my project to use a Teensy to control the system is on hold.
Does anyone have pics of the PCB inside ? Are those components likely repairable ? It's likely some TTL-type of buffer, but I haven't opened the case yet.
