Caps.
Propably , will go to my aunt that has esr meter to measure them before taking them apart for no reason
Now i have another problem.
Got some other monitor (generic brand, big store in my country brings them rebrands them and sells them). Wasn't turning on , the monitor led that has for turning on was blinking, so i took the decision to take it apart to see for bad caps. I dc'd everything and then i didn't connect that ccfl lamps to inverter and had a hissing sound. Took it 2nd time apart to see that problem. Connected everything and voila everything went working good as normal(monitor was working with no signal then connected to pc for 10 minutes worked no problems at all).
The question is now... is that i saw when i was plugging the vga-dvi connector with vga cable on it to the monitor that connector was making some little sparkles...got a bit afraid to be honest. I plugged the monitor with a dvi cable to my pc had same problems.
Sparkles maybe be some bad connections , some sort to ground or? Should i investigate further? (I will connect that monitor to my workshop pc so i want everything to be good...).
