Welcome,
Guest
. Please
login
or
register
Did you miss your
activation email
1 Hour
1 Day
1 Week
1 Month
Forever
This topic
This board
Entire forum
Google
Bing
Home
Help
Search
About us
Links
Login
Register
Electronics
Repair
Synthesizer main board. XP-80 CPU?
« previous
next »
Print
Search
Pages: [
1
Go Down
Author
Topic: Synthesizer main board. XP-80 CPU? (Read 681 times)
sampler1
Regular Contributor
Country:
on:
August 18, 2022, 11:54:25 pm »
Hi All something a bit different.
Im working on a synthesizer Roland XP-80 that won't boot. I replaced all the SMD Caps as many were leaking But it's still not booting. I am wondering if someone can shed some light for me . I checked the clock on the CPU ( IC12) HD6437034 and that seems ok. I then checked the Reset and its high. From what I read if its high the CPU should reset.
I have never checked RESET. Can someone clarify ? I think if the Reset was low the cpu would function.
https://www.synthxl.com/roland-xp-80/
Any help would be great!
Regards
Logged
“Electronic devices are powered by white smoke. When smoke goes out, device is dead.”
wasedadoc
Super Contributor
Country:
Re: Synthesizer main board. XP-80 CPU?
Reply #1 on:
August 19, 2022, 12:46:48 am »
No, the reset pin is active low. See the HD6437034 datasheet. Low resets the CPU. High lets it run.
Page 11 of
https://docs.rs-online.com/4ca5/0900766b80c2b5e5.pdf
Last Edit: August 19, 2022, 12:52:00 am by wasedadoc
Logged
sampler1
Regular Contributor
Country:
Reply #2 on:
August 19, 2022, 03:09:47 am »
Thank you !
So if I get this my clock is working and the CPU is running. Time to move on to something else.
Now the question is .
All the rails are ok, all the caps are changed, CPU is ok. Hummmm
Big thanks !
Logged
Print
Search
Pages: [
1
Go Up
« previous
next »
Electronics
Repair
Thanking...
EEVblog Main Site
EEVblog on Youtube
EEVblog on Twitter
EEVblog on Facebook
EEVblog on Odysee
