Electronics => Repair => Topic started by: sampler1 on August 18, 2022, 11:54:25 pm
Hi All something a bit different.
Im working on a synthesizer Roland XP-80 that won't boot. I replaced all the SMD Caps as many were leaking But it's still not booting. I am wondering if someone can shed some light for me . I checked the clock on the CPU ( IC12) HD6437034 and that seems ok. I then checked the Reset and its high. From what I read if its high the CPU should reset.
I have never checked RESET. Can someone clarify ? I think if the Reset was low the cpu would function.
https://www.synthxl.com/roland-xp-80/ (https://www.synthxl.com/roland-xp-80/)
Any help would be great!
Regards
No, the reset pin is active low. See the HD6437034 datasheet. Low resets the CPU. High lets it run.
Page 11 of https://docs.rs-online.com/4ca5/0900766b80c2b5e5.pdf
Thank you !
So if I get this my clock is working and the CPU is running. Time to move on to something else.
Now the question is . ???
All the rails are ok, all the caps are changed, CPU is ok. Hummmm
Big thanks !
