Author Topic: Tailgater satellite Dish repair ?  (Read 464 times)
Offline KD0CAC JohnTopic starter
« on: October 09, 2024, 08:09:00 pm »
Found a broken unit on craigslist , had a fall , took it apart and found one of the mounts inside for holding to gear base was broken .
That was an easy fix .
Now I am wondering if there maybe a timing / gear set issue , or procedure ?
Have not plugged yet , till I get some confirmation / to avoid more issues ;)
Did come with carrying bag , receiver-card inside , remote .
Re: Tailgater satellite Dish repair ?
« Reply #1 on: October 09, 2024, 08:12:58 pm »
Forgot another question , as I had apart saw some type of splitter , but on connection was open , I am under the impression that having a [ guessing ] 75 Ohm terminator should be inplace for interference / noise .
I think it came without a terminator , no sign of anyone else opening .
Online richnormand
« Reply #2 on: October 10, 2024, 01:09:03 am »
Have a look at this guy's channel:
Also do a search on Hackaday.
Lots of info there.
Best of luck with it and do not forget to have fun :)
Repair, Renew, Reuse, Recycle, Rebuild, Reduce, Recover, Repurpose, Restore, Refurbish, Recondition, Renovate
Online richnormand
« Reply #3 on: October 10, 2024, 01:16:13 am »
Here is one that goes in more details:
« Reply #4 on: October 12, 2024, 07:40:43 pm »
Seems like his stuff all about control / programing .
Did not see anything about electrical , mechanical info .
I had seen his channel a long time ago .
Thanks
