Hi David et al, here is my latest update. Adjusting the position control makes no difference to the -3.5 volt reading for either channel. I checked all the resistors in the trigger select circuit in situ and they were all pretty close except for R430. I removed R430 and it was 8.3k which is close to what it should be.
I measured all the voltages on U421. Most were as shown on the diagram except 3, 4, 12, 15, and 16.
Below is showing all the pin voltages in internal and external switch position.
PIN Internal External says should be with switch in Internal
1 +8 +8
2 +8 +8
3 -3.6 +0.9 -0.8
4 -2.5 * -2.5 * 0
5 -8 -8
6 +2.2 +2.2
7 0 0
8 +0.6 * +0.6 * Those marked * looked to have very small pulses on.
9 -1 -1
10 -1.9 -1.9
11 +0.6 * +0.6 *
12 -1.8 * -1.5 * +0.8
13 -1.9 -1.9
14 -1 -1
15 -1.8 * -1.5 * +0.8
16 -2.6 * -2.5 * 0
(Sorry the spacing seems to have got messed up when posting)
This morning I removed links W421, W422, and W444 also removed R436 and R701. This effectively isolated the trigger select circuit but the voltage readings on links 36,37,38 were the same, so were the voltages on pins 12/15, and 16 of U421.
Any guidance or words of wisdom much appreciated.
Thanks again.
Dave.
