You're sure they are tantalum capacitors and not Transient Voltage Suppressors ? It looks weird so many close together. They lack the codes that you expect on a capacitor like voltage and capacitance.I would desolder one and measure it, if it is a capacitance.
Found something for you! Take a look at the datasheet of the Vishay T55 series, the codes match for 10V 68uF maybe a different serie but that will be sorted out soon ,
