Author Topic: Tantalum SMD Capacitor Polarity Markings  (Read 2021 times)
Offline SoundTech-LGTopic starter
« on: April 12, 2020, 10:38:41 pm »
They are REVERSED the Band is Positive. :--
Offline jpanhalt
Re: Tantalum SMD Capacitor Polarity Markings
« Reply #1 on: April 12, 2020, 10:56:11 pm »
All solid electrolytics, even aluminum, are "reversed."  Wikipedia explains why.
« Reply #2 on: April 12, 2020, 11:41:01 pm »
Sad news about solids.
Offline james_s
« Reply #3 on: April 13, 2020, 03:16:54 am »
Why is this sad? It's always been this way, I don't see what the problem is. Before you use a part, read the datasheet, always.
Offline digsys
    • DIGSYS
« Reply #4 on: April 13, 2020, 06:05:44 am »
SMD can be a minefield .. markings, part numbering, packages sizes between manufacturers .. caps and leds definitely ... I always keep manufacturers charts handy, and if I come across a new part, I always download and print a description sheet FIRST !! ... and 1 in 100 times, even that can go wrong .. welcome to SMD :-)
Offline Zero999
  • 0999
« Reply #5 on: April 15, 2020, 11:04:10 am »
Where? It just states the polarity marking is opposite for solid, to wet electrolytic capacitors. No mention is made of the reason.
https://en.wikipedia.org/wiki/Electrolytic_capacitor#Polarity_marking
« Reply #6 on: April 15, 2020, 12:06:54 pm »
You want some fun, I have some old solid tantalum capacitors where the polarity is marked by the lead plating. gold and silver leads at each end, and I still have not got a definite datasheet for them either.
Offline Psi
« Reply #7 on: April 15, 2020, 01:07:53 pm »
Think you've got problems.
Sometimes the same manufacture will use dot=cathode for one color of led and dot=anode for another color led within the same product range.
