Author Topic: Tascam 32-2B capstan motor diagram  (Read 1225 times)
Offline BargainhunterTopic starter
« on: March 23, 2021, 04:06:36 pm »
I need a wiring diagram for the TEAC EM1449 capstan motor.  It is a 24V 12W motor.  I could not find a replacement so I am forced to rewind the armature.  I tried to take notes when removing the old windings but many layers were fused together and I lost track.  I am pretty sure there were 90 turns per coil.  The motor has seven slots.  I need to know if the coils advance clockwise or counterclockwise and the connections to the commutator.
The Teac EM1446 is similar but lower wattage. It may be wired the same.
If anyone can help me, I would greatly appreciate it.
Thank you very much,
Chuck
Offline cheater
Re: Tascam 32-2B capstan motor diagram
« Reply #1 on: March 23, 2021, 04:17:39 pm »
Try asking on the ProAud mailing list.
Offline hd1200xlh
« Reply #2 on: March 19, 2024, 03:53:40 pm »
Did you manage to get a diagram and info  for the motor rewind?
Offline amyk
« Reply #3 on: March 20, 2024, 12:22:43 am »
You can easily flip the connections if it turns in reverse. Just make sure all the coils are wound the same direction. As for the relative positions of the coils and commutator, this old book may help: https://archive.org/download/armaturewindingm00brayrich/armaturewindingm00brayrich.pdf
