Hi, have just joint this great forum and would appreciate any hints to repair the power board of my TV. Sound and faint image when lit with a torch, but backlight not turning on. Board number is 40-L402H8-PWD1CG.
The LED strips are all good, tested individually and all draw the same current at identical voltage; so guess the problem might be in the LED driver. Have just started to look into the board on the bench and will report back once I detect the problem, but in meantime any time-saving hints and schematic diagrams of this board would be great. Thanks!
Update: just found the driver OZ9976 presents a short circuit from Pin15 (VN) to ground. Faulty external components are excluded, as the short is still there with the pin isolated by cutting a small gap in the PCB track. At this stage I assume the IC is damaged, reason unknown.
The datasheet of the driver is very basic, anybody else experienced a similar fault or found a better datasheet ?
