Author Topic: TCP202 Tektronix Current Probe - need of EEPROM dump  (Read 1041 times)
Offline HarcownikovTopic starter
« on: December 22, 2021, 12:55:04 pm »
Hi!
Could somebody share .bin file of his TCP202 eeprom? By mistake i blanked it during opamp repair (esd?) and my TDS3024B can't identify now that i'm connecting current probe. Chip is ST 24C02W6.
Thank you in advance!
« Last Edit: December 22, 2021, 01:22:23 pm by Harcownikov »
Offline Teichhermelin
Re: TCP202 Tektronix Current Probe - need of EEPROM dump
« Reply #1 on: December 22, 2021, 08:54:24 pm »
Register from 3.01. one more time with me ... I can do this for you ...
Offline picburner
« Reply #2 on: December 23, 2021, 01:14:12 pm »
This is my 24c02 dump. You will have my TCP202's serial number. I don't know if you can change the sn with yours, maybe there is a checksum involved that I don't know where it is.
The following users thanked this post: fzabkar, Harcownikov
« Reply #3 on: December 24, 2021, 09:30:37 pm »
Lovely! Thanks a lot - your dump worked perfectly. Tektronix probes has a B at the beginning and 6 digits later in SN, this was clearly visible when converted from hex (see attachment).
I changed it back to my SN and flashed it, I can use my current probe without manually changing the settings again!
Thanks dude.
